I hear you J.J What would you suggestions be for a lawn system for 100' X 280' 4 zone with high pressure heads. 4bdroom 3 ba home with normal use. Tell me what you would do if you will?
thanks
Some people think that a sprinkler is so easy. These are just some of the things you have to know. Permits, dose your area require permits, and do they require a license sprinkler man.
Do you have well or city water? If city, you need backflow preventer.
First you have to have a good pump system. Will it be a dedicated pump, used for the sprinkler system, or used by all? If you already have it , start from there . Do you have 30 to 40 psi. How many GPM. Do you have a small tank that will let the pump come on and stay on for the duration of the sprinkler cycle. If not, some timers can supply to the 24 v relay which activate the pump at the start of the sprinkler cycle. Do you want a mechanical or digital timer. What brand of valves and spray heads so you prefer? Who is going to be doing all the work. Do you have a trencher, or will you rent one.
You first have to lay out the property, and add the house, garage, shrubbery, which zones need spray heads, spacing of the rotors for the larger area. Whether 4 zones will do this has to be determined. It really doesn't matter how many zones, you have to have enough water GPM and pressure for good delivery. If most of your shrubbery is combined, then one zone may cover all that. On the large areas, determine what spray heads you will be using. Most all have different nozzles for different requirements. Figure the area to cover. Some rotors will spray 45 ft with the right pressure, and the orifice on the spray head will determined volume in GPM. The sprinkler coverage should overlap, so as to not have gaps.
If you have never done this kind of work before, it will be a learning experience. Obtain a copy of your survey, make several copies. Easy way is to get one of the Rainbird layout booklets and plot your lot and house, and shrubbery. Tell them your GPM and pressure. Send it to them and they will put it on their computers and develop a sprinkler plan for you, with materials and locations, etc. Of course they would like for you to purchase Rainbird products. I use whatever, because none of them are bulletproof.
If you are going to draw this yourself, then you have to educate yourself on the types of stationary spray heads, rotating heads, valves, timers, etc.
I am assuming that most people know how to work with PVC pipe and fittings. Purple.cleaner. blue glue.fast setting. Teflon around screw fittings. How to wire up the valves, etc. Where to put the timer.
All this can be done by one person, but is easier if you had help.
If you had all this done, the cost would be around $1500, to $2200.
I used to do a lot of this before my feet starting , and now, they hurt 24/7. Woe is me.
I have more threnchers now than I did when working. I am thinking of selling some of them but you gotta live close. Shipping, you know.
