New Well Question
   / New Well Question #11
My inspector told me a big problem was people deciding that a good place to chain the dog was to the well pipe. That meant that Rover throughly fertilized the area around the well. You can guess the rest.
I'm telling you there is no limit to how dumb some people are.
For my 2 cents, regarding coliform, I'd say that a 30 foot well seems a might shallow to me. Maybe it would be worth finding out the neighbours' well/coliform situation and see how deep their wells are.
For certain, make sure it get taken care of.
   / New Well Question #12
Mark,
Well, two things come to mind. And keep in mind, I am not an expert, but I'll gladly share my experience and whatever I know...
Iron can stay in the water when flowing. It will settle out after sitting, but seldom settles like sediment, just "comes out". Chlorine brings dissolved iron out of solution, so shocking it makes it easy to filter, but brings out the hidden red stuff.
If your casing is rusted, not much to do. You can probably stop the rust from getting any worse by using a sacrificial rod. You put this in the ground and attach it by a wire to the top of the well casing. Make a good connection, just like for electricity.
This method was often used for buried steel fuel tanks years ago. The rod eats away, the tank remains pristine /forums/images/graemlins/cool.gif
There was a post on this board where Biron posted this link Galvanic Scale , which shows what metals to use to be sacrificial to which metals (in this case, find one above Steel, like Aluminum).
I was going to try the rust removal process shown here Rust removal... on a portable gas tank by hanging a sacrificial rod down the center, being sure not to touch the sides and running the battery charger. Wonder if that will help "seal" the rust out of your casing...?
Take a look at the link, and maybe some of those who posted can offer more opinions here. Let me know what they say...
Should work, though.
A water softener like a Water Boss (Lowes, about $600) with Red Out salt (softens, but made for iron) can help, if you don't mind filling it yourself with salt every few weeks and don't drain it into your septic.- Someone just mentioned using salt to kill weeds, maybe a good use for this drain water? /forums/images/graemlins/smirk.gif
Good luck with it and let us know what you do how you make out.
-JC
   / New Well Question #13
When I shocked my last well I discovered it full of ear wigs. After examining the well cover I discovered that there is a vent that was just a small opening from the inside of the cap to the outside air. Any little bugs or spiders could crawl through. So I jammed it full with fine grade steel wool. The next time I pulled the cap it was clean inside.
You also didn't mention your pressure tank. You need to bleed all the air from the top of the tank so that the chlorine makes contact with the entire inside surface. I also drain the hot water tank before I run the chlorinated water through the house so it gets completely filled. Some softeners can take chlorination, some can't. If you have one check with the manufacturer.
   / New Well Question #14
Where are you getting the sample of water to send to the lab.. the contamination can be from the screen on the water faucet.. or a whole house filter. One of things the tester did when getting a water sample from the kitchen sink.. was to pull the screen & guts from the water faucet.. clean it.. spray it w/ bleach.. then ran the water some.. then took the sample. If you have a whole house water filter.. I take the filter out.. fill the container w/ bleach.. send it through the lines of the house.
   / New Well Question #15
I take it from an outdoor faucet and flame the fixture with a torch first to kill bacteria.
   / New Well Question #16
I suggest the tub faucet or take the sample from the toilet tank. This is what my water testing company told me to do. I questioned the toilet tank and they said that there is no contamination worry from the bowl to the tank. They must know, because after I started to use them, I always used the tank water and it has been clear of any bacteria after the wells initial treatment.
   / New Well Question #17
Hey Guys!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Back on 4 a few anyway!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Being a marimechanic on and off since i was a kid and workin at a few boatyards in my time i would like to make a couple of quick observations...to use a sacrificial anode on steel uwould have to use an element/below the one trying to be saved....ie: boats use zinc sacrificial anodes to save aluminum castings such as outdrives....so to save the corrosion on a steel pipe you would probably use the same...
aluminum is actually as properly stated above steel on the anodic chart and would not "literally sacrifice itself" for steel...gold is the highest on the anodic scale and zinc is the lowest...in terms of corrodability... /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
And on draining all of the air out of yer "reservoir" tank ...
Be sure to replace it immediately after fillin it all the way with water...that bladder is what protects yer well pump from beating itself to death!!!!!LITERALLY!!!!!....it provides an air cushion that keeps the pump from hydraulically hammering the bottom of yer electric apart...it's actually caulled "pump hammering" be sure to put approx 3-5 psi less than the water pressure...and be sure that yer water psi gauge is on as far as psi!!!if you have to lmuch air psi in the bladderand your water psi goes down ...you can literally suck the bladder from its seat.....and remember to also let the air out anytime u drain the entire system /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Take care guys !!! love and miss ya'll
Todd from liddle ol maine!!! /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
p.s ..still have access to great wholesale on deep water well pumps.......am movin out of the farm today as he rented it so any phone messages can be taken at this #...207-685-3666
if you catch wendy just leave name and # for me to git back to!!!........... /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif...tootaloo /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
New LS170 Skidloader (RUNS) (A50774)
New LS170...
Duetz Power Unit (A50121)
Duetz Power Unit...
2014 Ford F-550 XL (A50120)
2014 Ford F-550 XL...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
