new X728 !!
   / new X728 !! #11
In my manual it says "The hour meter is counting time if the decimal point is blinking." This is like the blind leading the blind since I just bought the X500 yesterday. :laughing:
   / new X728 !! #12
yes, thank you. i see that one.
what i am wondering about is actually inside of the LCD hour meter display just to the left of the hours numbers.
thanks again
geek
Does it look like an hour glass Icon?
   / new X728 !! #14
Being a new owner of a x728 same set up other then an i have the 7 iron deck. I am having difficulty attaching the rear pto to the mower pto. I had to take it to dealer last time. Now i have been struggling for over an hour. it does not want to go on no matter what i do. an tricks. I have put the **** thing on ramps and tried to tackle from the back. not happening i cant seem to get this on
   / new X728 !! #15
Welcome to TBN scott,
I assume everything is clean and lightly greased on the splines. The first thing I check is to make sure the shaft telescopes smoothly. Then try to push the coupler on a little moving the belt to rotate the shaft to align the splines, once aligned I pull the collar back and push it on until the collar locks back in place. So far I haven't had to do any thing special such as jacking it up or reaching from behind the tractor.
   / new X728 !! #16
It can be kind of a pain on my x748 also. I do what Steve said, except I put the PTO selector on "rear" so the mid PTO free wheels...This makes a HUGE difference, it just slips right on. I don't know if you have the rear PTO option or not.
   / new X728 !! #17
Congrats on new x728. With the 1026r and 60" drive over deck ,did not get auto conn MMM . I had put some light grease on the collar, on the splines of shaft and gear and was still having problem ,oh had the PTO set to the rear.
Finally after 15-30 min of getting madder and madder decided to try something else , sprayed some WD40 on splines ,slides on with no trouble . Have been spraying WD40 now every time ,works first time every time. Light grease so far hasn't helped , maybe with more usage it will get easy, or order the auto connect like I did last week.
REYNOLDS 14C SCRAPER (A58216)
REYNOLDS 14C...
2001 Ford F-650 Water Truck, VIN # 3FDWF655X1MA82619 (A57453)
2001 Ford F-650...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
207273 (A52708)
207273 (A52708)
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
