Newbee turning plow question
/ Newbee turning plow question #1
Gerferd21
NC
Kubota L2650
Hey all. This is my first post to the forum and I need some opinions about my tractor. I've got a Kubota L2650 4X4 and I want to use it to pull a double turning plow (probably 14"). I don't have one yet. The tires on the rear are pretty wide, 20" or so. My question is will the wide tires make it hard to plow since they'll probably ride up on the side of the furrow? Would I be better off using a single wider plow?
/ Newbee turning plow question #2
Most 3-point mounted plows, 2-bottom or bigger, need the tractor's wheels set to have roughly 52" between sidewalls. (26" from centerline of tractor to inside of right sidewall) Otherwise, you're adjusting the plow to where it will have a difficult time following with the draft line of the plow on the centerline of the tractor, and still having the furrow side wheel in the furrow. Many compacts have a tough time fitting that criteria. (especially so with wider R4's)
There are single bottom plows made that fit compacts and subcompacts better. And with a single bottom, you can compromise the plows adjustment to fit the tractor's track width and not create a situation where the plow is difficult to pull.
More often than not, a plow will open up a furrow wider than the actual cutting width. It may cut a swath 12", 14", even 16" wide, but it moves that swath of plowed dirt several inches further than it's cutting width. I've plowed literally hundreds of acres with a tractor that has 18.4X30" rear tires and the plow I used was a 3X14". The furrow open furrow usually ended up being 18" to 20" wide. And even if you end up with an open furrow that's an inch or so narrower than tire width, not the end of the world.
OK thank you for the info. I ended up getting a Ford single bottom 12" (with a 14" point installed) yesterday. It can be shifted left or right of center so I may play with that and see what difference it makes.
FRONTIER LR2072-72" LANDSCAPE RAKE (A62130)
FRONTIER...
5x10 Utility Trailer (A61165)
5x10 Utility...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2003 Chevrolet 2500 Savana Van (A63116)
2003 Chevrolet...
Adams Nurse Trailer Tank (A63118)
Adams Nurse...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
