Newbie Drawbar Question
   / Newbie Drawbar Question #1
wyeguy
Bartlett, Iowa
Ford 1100
I have a trailer hitch ball on the draw bar I got with my tractor. The draw bar rotates between the lift arms, so I have to turn it to get the ball upright to hook up a trailer. I saw something like a swinging draw bar link that attaches to the center position on the back of the tractor, which would stop the draw bar from rotating, but would I still be able to raise & lower the draw bar with the lift arms?
   / Newbie Drawbar Question #2
If you do a search in the "Build it yourself" forum you will find many variations of 3PH trailer movers that are practical and inexpensive add ons for your tractor. Some have places for carrying chains, toolboxes and most are designed to use the 2" square receiver mounting system so you can quickly change out the ball mounts. All that I have seen will raise and lower with the hitch which is the whole point in using it to start with.
   / Newbie Drawbar Question #3
Tractor Supply has them starting @ 19.00 depending on the size you need.
Great advice, guys. Thanks!
   / Newbie Drawbar Question #6
yep.. the limple lil cat 1 DB locks at TS are fine...
HAMM HD+120i SMOOTH DBL DRUM ROLLER (A52706)
HAMM HD+120i...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2013 DODGE CHARGER SEDAN (A56129)
2013 DODGE CHARGER...
Club Car Electric Cart (A55758)
Club Car Electric...
1961 Great Dane 40' Flatbed (A53316)
1961 Great Dane...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
