Newbie Lenar owner with question
   / Newbie Lenar owner with question #1
Greygoose
TYM 394
Hi everyone-
Great site by the looks of things-thanks for having me! Anyway,just wondering if anyone knows if I have a seperate oil supply for my injection pump.It has a fill opening,the manual says nothing about changing the oil in it though-only the engine oil.Machine is 2005 Lenar 254II.Thanks very much,
Mike
   / Newbie Lenar owner with question #2
Take this over to the chinese section. You will get more responses.
good luck, Dave
   / Newbie Lenar owner with question #3
Hi everyone-
Mike
True , moving to the Chineese forum will get more response
Hi
Current Lenars are now basically Mahindra 254I's. A quote from a DF dealer summarizes. A 2005 may very well be a DF (Dongfeng 254) .A photo would help to make sure and then determne the engine model and make. I have a DF 354 which has the slightly larger but same engine as the DF254. It does have its own reservoir for the injection pump ( takes about .8 l.). Opinion varies but you can probably change it when you change your engine oil with the same oil. The newer engines injection pumps are starting to be lubricated through the main oil supply and would not need separate changing. Pretty sure yours does not fall into that category being a 2005.
"The origianl Lenar tractors were Jaingling, previously called Feng Shou, and now part of Mahindra. When the Jaingling factory was sold to Mahindra, LENAR production was transferred to DongFeng, who had previousley supplied the Taskmaster and Avenger tractors imported by Roger Powells companies."
Good luck
Dave
Here is a couple of photos of the machine.
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2025 Swict 66in Bucket Skid Steer Attachment (A55787)
2025 Swict 66in...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
