Newbie Looking for SubCUT Buying Advice
   / Newbie Looking for SubCUT Buying Advice #11
RSD, you mention your primary chores are mowing (hills) and snowblowing a 600 foot driveway, with some light landscaping and hauling. I echo Bob Skurka and suggest you check out the Ventrac and Powertracs along with the more conventional sub-cuts.
I played with both the Ventrac 4200VXD (with loader) and the Powertrac. Both would be great machines for your needs. I (IMHO) think Ventrac is mower first, tractor/loader second; Power trac is loader/tractor first, mower second.
If you are spending most of your time mowing a Ventrac is great. [BUT its not cheap. It's more than a similarly equiped Sub CUT.] It can climb hills you wouldn't want to look at with a SubCUT. And with the Ventrac 4200 you can get a limited 3pt hitch (no rear PTO, just the hitch) so you can pull blades and other non-powered implements.
If the Ventrac dealer in my area didn't stiff me (closed the shop early and wasn't there after I drove an hour and a half to talk to him) there might be one in my garage.
I love my B2410, but I keep it on the flat parts of my property, or I drive it up and down the dirt road. I don't go sideways. If I had to, I would have a PT or Ventrac. I keep hoping I'll get a big inheritance and be able to buy a second machine without my wife making me sleep next to it in the garage.
   / Newbie Looking for SubCUT Buying Advice #12
For low center of gravity and stability on hills you definitely need a sub-CUT. For ease of changing attachment you might look at JD. for price look at Cub Cadets new 5000 series that offer all wheel drive diesel power at a more affordable price. look for package deals. I use my 2210 on the sloped ditch along the highway out front. very stable. so stable in fact that if the slope is a bit wet the front tends to slide a little. You'll find each model has it's own faults, find out what they are and weigh against what you like.
   / Newbie Looking for SubCUT Buying Advice #13
Based on your primary uses--mowing and snowblowing--that a SCUT (or powertrac/ventrac) would be more suitable than a CUT. In this situation, the only reason I could see justifying a CUT is if you have any woods that you intend to work in--because in the woods, the increased ground clearance of a CUT over a SCUT is nice.
2013 Ford F-550 Bucket Truck (A56858)
2013 Ford F-550...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
POLY TOTE W/ WIRE CAGE & PALLET (A52708)
POLY TOTE W/ WIRE...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
