Randy!Youare said:The tree grew towards the power line becasue there was more light in that direction. Getting a tree to fall against it's natural lean takes and act against gravity, which can be done.
There are several unknowns at this point which can influence whether or not this tree can be dropped from the ground or if it has to be taken down from the top to the bottom. What is the over all health of the tree, is there a chance there is rot in the base of the tree or in the trunck? Should there be any question of the vitality of the hindge wood I would suggest it be taken down a piece at a time from the top.
Getting a tree to fall in the direction you want it to go against a lean will take leverage as high up as you can get it. As many others have suggested a GOOD strong rope is essential. I use a rope puller and a 1/2" high strength rope. The rope puller is designed to pull rope and has an advantage over a come-along in that the pulling range is whatever your rope length is. The one I have is rated for 1400 lbs.
Once you have the rope positioned as high up as you can get and your rope is longer than the tree you are cutting which is fastened to an object heavier than the tree put a little tension on the rope. Make sure you are pulling in the same direction as your notch will be facing.
Make your notch facing the direction you want the tree to fall so that the width of the notch is at least 80% of the tree diameter. Your hindge wood thickness should be at least 10% of the tree diameter but you can leave a little more if it makes you feel better. Remember you have to break this band of wood to get the tree to begin to fall. Picture a 2X12 standing on end in the ground and the force it takes to break this off by pulling on the top and you get an idea of how much the hingde wood can hold.
Directly behind where your notch cuts intersect bore into and through the tree a couple of inches behind this point, here you will establish your hindge before you complete your back cut. Once you have cut foward and made your hindge start cutting towards the back of the tree. You can cut one quarter of the back wood away and leave one quarter holding. Insert a plastic felling wedge and tap it in until it is good and tight.
Cut around from the other direction but leave a small strip a little more than the chainsaw bars width from the first wedge of holding wood. Insert another felling wedge. Knock both wedges in until both are tight alternating hitting one then the other. Here is where two people come in handy. Have the other person increase the tension on the rope.
Sometimes the tree will start to fall at this point, the little remaining holding wood you left between the wedges breaks and the tree falls in the direction you notched it. Sometimes the holding wood needs to be cut before the tree falls. Knock your wedges in once more. If you need to take your saw and cut the holding wood between the wedges, the wedges will keep your saw from being pinched. Once this holding wood is cut the tree should begin to fall in the direction you want it to, keep putting more tension on the rope until you are certain the tree is on it's way.
One way to tell if you have the rope up high enough and enough leverage is before you cut put some tension on the rope, if the top of the tree moves in the right direction you've got it.
Randy
An erudite explanation of a logical process imbued with obvious experience and sprinkled with tidbits of common sense. Most appreciated!
Ken
