Newby from NY looking for a sub compact tractor
   / Newby from NY looking for a sub compact tractor #21
Right now I have 3 acres of which roughly 1.25 acres is currently cleared with our house on it. I would like to clear the brush and some of the junk pines off the rest of it. which there isn't a ton of larger trees on it. I figure I can hire a dozer do the initial clearing and then do the cleanup and property maintenance with whatever I decide on. I will probably use a box blade to smooth things out and then utilize either brush hog or finish mower to keep things in order. I will also be using a PHD for fencing and maybe to plant some trees around. In addition I'll need to run a tiller for a decent size garden, but I think a 4 foot tiller would be plenty. Also I don't want to get too big, because I would like to run a MMM on the lawn around the house and storage is a concern so I would really like to have one machine do everything. Not too mention the fuel economy of a diesel would be better than my Husqvarna which to say the least is a bit on the thirsty side and it only has a 48" cut on it. I should have went with the 52" at a minimum, but those models simply could not be had at any Husqvarna dealer within 100 miles of me for at least another 3 weeks when I was looking to buy and the grass simply would not wait that long! I'll not make that mistake again, if I can help it.
Somewhere down the road, I'll inherit probably another 5 acres next to my current property but most of that is cleared with some light brush and is basically a former horse pasture as our property was when we had the house built 2 years ago. So basically a brush hogging or finish mowing every few weeks to a month would keep that section up fine.
Current models I'm looking at are, Mahindra Max either the 25 or the 28XL, J.D. 2000 series, Kubota B series, Massey Ferguson 15 series, and I just might check out Kioti, LS, and Bobcat in my search as well.
Sounds lke a SCUT might do it for you. typically 4' implements, mmm that won't tear up your lawn, and much more versatile than a garden tractor. Too bad you don't have a Yanmar dealer in your area, you can save $$ over other machines, and you get dual hydraulic pumps, and shift on the fly, which no one else has. All the others are pretty good as well.
   / Newby from NY looking for a sub compact tractor #22
   / Newby from NY looking for a sub compact tractor #23
I would get a CUT sized tractor if you are going to be taking care of the other 5 acres(or if you are sure you will get it in the future). It sounds to me like you will need the extra ground clearance that the CUT will offer as opposed to a SUBCUT.
I've already been told I'm getting the extra acreage from my Uncle who owns it. With that in mind, once I got my place straight I would likely start taking care of it early any how.
   / Newby from NY looking for a sub compact tractor #25
I would suggest something around the 30 hp compact size with the added acreage. Maybe the new Deere 2032R or similar Kubota B series, Mahindra Max28 would be the least I would consider. Get something with the higher pto hp in that frame size as it will speed up your mowing.
   / Newby from NY looking for a sub compact tractor #26
I think a B3200 or B3300SU would be a decent size for you. It is a little on the large size for mowing but it still would be okay. One thing I like about the B series over some of the competitors is it has a 3 range hydro versus a 2 range.
   / Newby from NY looking for a sub compact tractor #27
I like the three range hydros better too, some of the small NH are three range.
Do those have position control on the 3 point? I do like the idea of 3 ranges, but I don't know how necessary it is for my application.
   / Newby from NY looking for a sub compact tractor #29
B3200 does not have position control. Idk about the b3300. 3 ranges would be useful for most anything.
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
WOODS TBW15.40 LOT NUMBER 59 (A53084)
WOODS TBW15.40 LOT...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2014 TAKEUCHI TS70R SKID STEER (A51246)
2014 TAKEUCHI...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
