Newest addition to my family of tractor implements
   / Newest addition to my family of tractor implements #41
Re: Final pics of new rake
To work without a hassel the teeth need to be close to perpendicular to the ground and need to ride up as well as back when encountering an object such as a rock or stump. That is why the pine needle rake has a long horizontal section on each tine, it allows the rake tines to ride upwards without dumping the collected debris. Also similar to a leaf rake the last two inches of the tine is hooked slightly forward. You may be able to bend the lower tines slightly forward in this manner and adjust the tines themselves closer to plumb.
Keep up the good work.:thumbsup:
   / Newest addition to my family of tractor implements #42
Think we are talking about two different things... look at the photo... toplink is circled in red. Twist it to make it shorter.
   / Newest addition to my family of tractor implements #43
Nice work ... I agree try screwing that top link in to shorten it.
I would do that but it messes with the angle of the tines. Because the tines are on a torsion spring the tines bend back too easily. They pretty much need to be facing forward in order to effectively scoop up the grass. As it is, the resistance they get in the grass and on the ground does bend them. I really need to shorten that top link. An alternative would be to attach my eye bolts lower on the post.
SI2305
   / Newest addition to my family of tractor implements #45
SI2305
If your happy with the angle of the teeth then I'd say you have nothing to change. By the looks of it you have room to change your angle by screwing the top link in or out
   / Newest addition to my family of tractor implements #46
I merged the threads again. :thumbsup:
   / Newest addition to my family of tractor implements #47
That's good to know, I thought I was drunk or something :confused2::confused3::drink:
thanks for merging the threads again. I think my problem earlier was an iffy internet connection. I would have to guess that the page did not load completely, thus causing posting problems. Reloading the page just caused the cookies to reload the same problem again. Creating a new thread created a new post undeterred by cookies.
thanks and sorry for the confusion,
SI2305
jenkinsph added
"Also similar to a leaf rake the last two inches of the tine is hooked slightly forward. You may be able to bend the lower tines slightly forward in this manner and adjust the tines themselves closer to plumb."
Actually, I rather like this idea. I found that I do need some forward facing angling on the tines. Getting those heavy duty spring steel tines to bend will not be easy. I found that just angling the entire assembly forward does the job. Right now I have the rake off and in the garage. I wanted to make some cuttings this weekend to bring the entire assembly into a better position. Unfortunately, the wood is soaked from rain as it rained for most of the weekend. I wanted it to be at least partially dried so as to minimize any warping or twisting as it dries out.
Thanks all for all the input. I really appreciate it and some of your ideas have made their way into the design. I am tinkering about the idea of adding threaded rod to both stabilize and re-shape. I am about to lower the toplink, but I have to make sure I don't mess up the cross-bracing.
As it stands, I have raked a heap of grass in its present configuration--far more than I expected. I have piled up the clippings into a 30-40' windrow about 3' high and about 5' wide. My goal is to have the pile slowly rot over winter, kill the existing live grass beneath (it is mostly dead from some earlier pilings now reduced to about 6") and eventually plant raspberries
Once again, I am grateful to all who have helped,
SI2305
   / Newest addition to my family of tractor implements #50
Might want to consider adding some nitrogen fertilizer to the pile and cover it up with black plastic. Should make it break down faster.
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2461 (A58376)
2461 (A58376)
Caterpillar 906M (A53317)
Caterpillar 906M...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2008 FORD F-550XL SUPER DUTY INSULATED BUCKET TRUCK (A60430)
2008 FORD F-550XL...
