NH 2332 running away in cold
   / NH 2332 running away in cold #1
Me
Northern Michigan
I just bought a leftover 08 NH 2320 45hp 4cyl, and this winter was its first. When it was very cold the motor would run away until it got up in temp a bit. Anything below 20 degrees you had to be sitting on the seat ready to shut the key/fuel off because it would start running away, and would go right past redline. I was lucky I happen to be standing beside the machine the first time it did it.
Depending on how cold it was I would have to shut it off between three and ten times before it would idle correctly. I called Purdy's and talked to their head mechanic and he had never heard of one doing that and there was no TSB on it. Purdys is about half a days drive from me, so to haul it down when they have no idea what to look for seems silly, especially when it only does it in very cold weather. The tractor only has 70 hrs on it, so I need to get this resolved this year before the warrantee is up, but I was hoping that someone else has experianced this.
Has anyone had this experiance and if so did it get resolved?
Larry
Really, I'm the only one that this has happened to?
Dealer has no clue, says plug it in, which is not an option where I store the tractor.
   / NH 2332 running away in cold #4
The only thing that could casue that is the govenor, right? So i would study the manual for your model and try to figure out what would cause it to act differently in cold weather.
38x18 Open Rim (A46502)
38x18 Open Rim...
Ingersoll Rand PD-24 Double Drum Vibratory Roller - Low Hours/Jobsite Ready! (A48561)
Ingersoll Rand...
FLARE STACK (A47001)
John Deere 336 Square Baler (A46502)
John Deere 336...
2011 Chevrolet Silverado 1500 4x4 Pickup Truck (A46684)
2011 Chevrolet...
2018 Bobcat S650 Skid Steer (A46502)
2018 Bobcat S650...
