NH #3930 PTO HAS QUIT
   / NH #3930 PTO HAS QUIT #11
Try disconnecting the engagement lever from the splined shaft, rotate a little, then reconnect it.. might give a little more life to a damaged clutch. If that works then fine-tune adjust it to where engagement takes place at about 2/3's of the throw distance between stopped and spinning, then re-adjustment the "slip" bump stop.
That lever is worrisome, I've never left mine at the "slip" detent, but I have knocked it off of full engagement many times with my leg.
   / NH #3930 PTO HAS QUIT #12
That's absurd. Do you have any idea how the PTO clutch on a 3930 works? The lever operates a hydraulic control valve spool. Altering the stroke of the spool can do nothing but degrade clutch operation, one way or the other.
   / NH #3930 PTO HAS QUIT #13
Just started having issues with my 3930's pto as I started to use a bushog the other day. Engaged pto and it quickly disengaged and would not attempt to come back. Now I have noticed the 3 point lift is not working either. I have herd of these shafts breaking in these tractors. Could someone give me information on the trouble shooting the hydraulic pto drive system. Praying I can rule a broken shaft out and move on to a simple relief or something. Thanks for any advise.
   / NH #3930 PTO HAS QUIT #14
you have tagged onto a 7 year old thread. you will get more hits if you start your very own new thread!
   / NH #3930 PTO HAS QUIT #15
I was hoping it would notify one of the previous posters and they could help me out with the issue. I have started one in the parts and repair with no reply.
   / NH #3930 PTO HAS QUIT #16
i think i'd have started one in the NH section, since it is a NH tractor!
As for previous posters, depends on if they were set to subscribe to the thread, or if they removed the subscription, .. or if they are still here.. ( one of the guys for sure is )... but remember.. 7 years is a loooong time.
   / NH #3930 PTO HAS QUIT #17
Hey! That's a good idea an will do that. Thanks.
   / NH #3930 PTO HAS QUIT #18
however.. i doubt you will get much better advice than you are already getting on the ford forum at ytmag. ( ps.. rickb is a member here and there... but sean is pointing you in the right direction.. check hyd fluid, then pressure.. do you have remotes? )
   / NH #3930 PTO HAS QUIT #19
Checked fluid. Going to check pressures this afternoon. I have two remotes and both are working well. Just lift and pto giving problem.
   / NH #3930 PTO HAS QUIT #20
2 pump system or 1?
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
Unused Quick Attach Plate (A55272)
Unused Quick...
TOPCAT BDRC ARTICULATING BRUCH CUTTER (A58375)
TOPCAT BDRC...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
LOT: (8) Wheel Loader Bucket Teeth (A59076)
LOT: (8) Wheel...
