NH 451 mower - bar is bending too much
   / NH 451 mower - bar is bending too much
drw, you are right it is the gag linkage that was out of adjustment. First, the box tube frame bar is supposed to be set at 16-1/2" above the ground when the 3-pt hitch is lowewred. Then the gag post should lean toward the cutter bar so it has 1/2" to 5/8" clearance under the inboard end...The book also shows an extender bracket on the gag chain for use with a 9' bar. Take care, Dick B
This is actually the solution. (And btw, my 9' mower does indeed have that extender bracket, as required).
Getting the gag post to lean forward was quite a chore. I had to remove all the cables just to get it to budge. Now to put it back together again without removing the clearance on the gag post. :eek:
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
40' CONTAINER (A52706)
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
1347 (A57192)
1347 (A57192)
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
10ft Enclosed Cargo Trailer (A55853)
10ft Enclosed...
