NH 640 baler or JD 335
   / NH 640 baler or JD 335 #1
truckerr1
Peterborough,ON
Landini Vision 105
I would like some opinions as to which baler is better,a NH 640,4X5 with auto wrap twine tie (mechanical)hyd tensioner,wide p/u,gathering wheels for $5250 or a JD335 4X4 in good cond with newer belts for $5500. I do abt 100 bales ayr.:confused:
   / NH 640 baler or JD 335 #2
The wider pickup, AutoWrap simplicity and 4x5 capability give the 640 the edge if overall condition is similar. If the 640 has good belts, the newer belts of the 335 aren't significant.
   / NH 640 baler or JD 335 #3
The lack of a monitor box and NO auto wrap on the JD would be a deal killer for me. Having to manually control the twine arms gets to be a pain. I still remember the "crick in my neck" feeling when I baled with a JD 410 that had no monitor and looking back often was required. Plus I don't like the limitation of 4' diameter bales. As a rule of thumb the last 6"s of diameter contain 20% of the weight of the bale.
   / NH 640 baler or JD 335 #4
Jim, You confirm my suspicion that the 335 sold against the NH 630/634/638 balers. Manual electric tie, light duty 4x4 econobox machines. I despise those balers.
   / NH 640 baler or JD 335 #6
Rick
I guess those type balers are all right for someone that bales just a few bales a year but not for me. I like being able to bale 30+ bales per hr(depending on the thickness of the hay) and that ain't happening very easy with a manual tying machine. There's a Big difference in baling a couple hundred bales a year and several 1000 a yr. Then one throws in the speed of netwrap and that will spoil the baler operator.
Thanks for your input guys,I"ve decided to go & have a look at the NH640 next week. It is at a dealer abt an hours drive from me. Do these balers have any particular issues i should look for besides the obvious,belts,bearings,etc?
   / NH 640 baler or JD 335 #8
Rick
Exactly.
   / NH 640 baler or JD 335 #9
Check the bearings & spur gears on and between the dimple rollers mounted on the pivoting frame called the 'sledge frame'. If hooked to a tractor, ask the seller to slacken the belts so you can check the bearings on the various rollers carrying the belts. With the baler running, trip the tying mechanism manually using the lever at the right front corner of the machine. The twine arms should drop to the center, then advance slowly back home and disengage.
   / NH 640 baler or JD 335 #10
I had a NH 644 auto wrap and was a good baler. Very easy to operate.
Sent from my iPhone using TractorByNet
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Tailift FG35P-GML Forklift (A53117)
Tailift FG35P-GML...
