NH Supersteer An exclusive feature??
   / NH Supersteer An exclusive feature?? #21
Hey Equipman,
The new M100 also has it.
Do you have any experience with the Big 100 series Ms?
   / NH Supersteer An exclusive feature?? #22
Woodbeef
We saw them (M105S) at the dealer meeting and were very impressed with them. A longer wheelbase tractor with a much shorter turning radius. 105 hp engine and 93hp PTO, 4 cylinder, turbo with intercooler, 2WD or 4WD. I didn't remember the bi-speed turning feature and will have to check on that. The 16 X 16 trans like the M110 and M120 is a great transmission.
Lewis
   / NH Supersteer An exclusive feature?? #23
What makes is more difficult for loader work??
Also, anybody know why no other company offer an equlivant of Supersteer on there tractors.
thanks
Mostly because it isn't needed. Just a bit of added bling. :)
   / NH Supersteer An exclusive feature?? #24
Most of the guys around here that go for the Supersteer option use it for orchard work. Works real good in those close quarters.
If I didn't need it for a specific purpose, and did a lot of FEL work, I would not -and did not- get the Supersteer. Those NH CUT's turn real tight without it, especially if using the split brakes.
   / NH Supersteer An exclusive feature?? #25
Murph I agree with you. Most of my work is finish mowing on 9+ acres so the SuperSteer is right handy. However I did get the FEL to play once the mowing work is done. It's so easy to take the 17LA off that I do not mow with it in place.
My experience is much the same as this. It has been several years now since I owned a TC33DA with supersteer, but I used the tractor for mowing mostly, and it was great, No, better than great it was fantastic. It took a little getting used to loader work with it, but once mastered, not a problem But for all of its praise, I would not own one here in Branson, with all the hills I traverse, the thing just turns TOO sharp, and would get me in trouble here. So summation: if you are on flat ground, and mow mostly, cant be beat. If you live on hilly ground, better get the standard axle. IMHO
James K0UA
   / NH Supersteer An exclusive feature?? #26
The specs show my TC40DA w/o SS has 127.5" turning radius at 54 degrees (no brakes). SS is a 113" turning radius at 75 degrees. The 8N is the same as the TC40DA w/o SS. With SS and split brakes you could almost turn on a dime.
   / NH Supersteer An exclusive feature?? #27
How does the supersteer get you smaller turning radius. My LS tires turn till they almost hit the frame. It couldnt turn more unless the axles were wider or had smaller tires. I dont know what the turning radius is and the website doesnt list it, but it is pretty small without the brakes. How is this measured. Is it by making a circle with the tractor and then measuring from center of the inside tire cirle to the center of the tread on the inner circle or from the center of the circle to the outside tire circle center of tire tread.
   / NH Supersteer An exclusive feature?? #28
I found some additional info on my tractor on a UK website that lists a 55 degree steering angle and 125.9 turning radius. That isnt bad for a 72 HP Tractor with 86.6" wheelbase and 157.08 overall length, figures out to 1.45 times its wheelbase and it doesnt have Super Steer.
   / NH Supersteer An exclusive feature?? #29
How does the supersteer get you smaller turning radius. My LS tires turn till they almost hit the frame. QUOTE]
Supersteer not only turns the front hubs (normal steering), it also turns the entire axle (similar to a little red wagon). The mechanics of this is very simple yet very ingenious.
If I remember correctly the the steering cylinder is attached to the axle instead of the hubs. The hubs are attached to fixed points on the frame. As the front axle rotates, the hubs also rotate. This provides a much tighter turning circle.
   / NH Supersteer An exclusive feature?? #30
There are some pretty good videos of this on You Tube. I don't think I would care for it, but I am sure it has its uses.
44029 (A51692)
44029 (A51692)
KUBOTA M7-132 (A53084)
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
