NH T4020 error code 2011 won't move
   / NH T4020 error code 2011 won't move #1
SETexan
Austin County, Texas
New Holland T4020, NH TC48DA, Ford NAA GJ
I have a NH T4020 with shuttle shift. The tractor starts and runs. When I put it in forward or reverse it does not engage or move. The dealer thinks the clutch/pressure plate is the problem, I do not. The cost to break the tractor apart is about $5k. I think the problem is simpler than clutch/pressure plate. The 2011 code is a clutch related code but states the potentiometer too low. Where is this potentiometer and how hard is it to replace? Where are the relays for all these safety systems? I am just wanting to prove the clutch is not damaged. Any help will be greatly appreciated!
Information on tractor are as follows:
2012 NH T4020 I bought new.
Tractor never abused or even worked hard.
138 hours in the clock.
I had a error code in the past that was different than 2011 but the tractor would not move.
I think this a cheaper simple fix but want to make sure the tractor doesn't need a clutch before I spend the money to break it apart.
   / NH T4020 error code 2011 won't move #2
Have you reset the code and have it reappear? I would confirm it is a legitimate code first.
False codes seem to becoming more common now days.
Thanks for the response, how do you reset codes?
   / NH T4020 error code 2011 won't move #4
Not sure how tractor OBDC connectors are structured. It may be possible to use the same reader for a car as a tractor. Or maybe a adapter.
Do you have your own code reader? I use one on my cars to determine what the code means and then erase them to verify it is a real error and not a false code.
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
