NH TC 25 Bucket Tilt Issue
   / NH TC 25 Bucket Tilt Issue #1
dougcat
White Hall, MD
2004 NH tc25, NH 3045, Exmark Z 60" and 72 (35hp), Bobcat t590, JD GT245, Kubota 3060 4X4 (60"-72" deck)
NH TC 25 All was well prior to a hyd fluid service this winter. Just scooped up a load tilt the bucket back and it falls slowly down. Dumped the load it still falls but at a slower rate. Checked the fluid level and for leaks they are fine. Ran the bucket fully in all directions all is fine no other issues that I can determine. Any thoughts? TIA
   / NH TC 25 Bucket Tilt Issue #2
Maybe a quick disconnect on one of your hoses not seated fully. Did you have any disconnected recently?
I did not disconnect. I will try to disconnect and reconnect as well as back and forth a few more times.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
