NH tc45da uses coolant
   / NH tc45da uses coolant #1
Marslander51
New Holland TC 45DA
My 2006 new holland boomer has been using some coolant. I noticed the overflow tank was empty and was able to add a whole gallon of premix coolant directly into the radiator.
I’ve never seen signs of leakage , and the engine oil is at a stable level and shows no sign of coolant present .
I guess it’s only leaking when hot and steaming off. How can I determine the cause?
Jim
Alaska
I should add it’s been six months and probably 20 operating hours since I had checked the coolant.
   / NH tc45da uses coolant #3
Yikes. That's a lot of coolant to account for in 20 hours of use. I would start by taking a very close look for a leak, particularly at the radiator hose connections, and all around the engine / radiator.
What does the exhaust look like?
   / NH tc45da uses coolant #4
I have noticed a slight drip from two locations on my TC45DA it has just over 1230 hrs. The radiator tanks and the block drain.
I am planning to remove the radiator and have it cleaned and pressure tested and fixed as needed. When I do that will replace the block drain petcock.
You might want to check those two things.
Beyond that I would check the water pump weep hole and the bearings for wobbling before delving into engine stuff.
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
Kubota BX25D (A53317)
