No Brake Controller on new truck
   / No Brake Controller on new truck #1
fluffhead31
Colchester, Vt
NH TC35A w/ 16LA FEL
I bought a 2009 F150. It has no brake controller yet and i need to trailer my tractor today. The truck and trailer both have the 7-way adapter. I'm wondering how the trailer will respond in the absence of a controller. Will there simply be no power to the trailer brakes? Or will the brakes be set to a default level?
   / No Brake Controller on new truck #2
You will have no brakes on the trailer.
   / No Brake Controller on new truck #3
As was said you'll have no brakes unless the trailer is a surge brake...Buy a controller and the wiring adapter..Takes longer to find a place to mount it than it does to install at least that has been the case on my Gm's
   / No Brake Controller on new truck #4
all newer trucks that i have messed with already have the trailer brake harness under the dash. All you need is a brake controller and the appropriate truck model adapter kit (Napa, Auto Zone, etc) and it takes about 10 minutes to install. Just dont go cheap on the controller. The more expensive ones do a much better job at adjusting the trailer brakes so they dont lock up under different loads. Mine increases the braking capacity of the trailer at a greater rate as you push down harder on the brake pedal. Mine never lock up.
   / No Brake Controller on new truck #5
Your truck is prewire, you can get a factory one from the dealer, just pop out the storage tray and plug in. The dealer reprograms the computer. The trailer settings will then be diplayed on the dash.
Or you can install an aftermarket one, the wire connector is attached to the back of the storage tray or filler panel.
Dave
   / No Brake Controller on new truck #6
   / No Brake Controller on new truck #8
Don't mess around. Not sure how far you are hauling but any distance is worth brakes. Don't chance it, get the controller. Safety first. Would you risk: no safety chains or not locking your load down to the trailer? You will be happy and more comfortable after you install it.
Sent from my iPad using TractorByNet
   / No Brake Controller on new truck #9
Dave
Exactly what I was going to suggest. I did this when the 2013 F150 I bought came without a controller. As Dave says, a dealer will have to reflash your computer. Maybe cost a few bucks more than an aftermarket/screwed to your lower dash model but it looks like it belongs there (because it does) and is meant to work with your truck's computer.
   / No Brake Controller on new truck #10
Go aftermarket. Get a Prodigy.
To add the OEM brake controller, you will need more than just the actual controller and programming. You will also have to change out the master cylinder.
I added a Prodigy to my 2008 Expedition. Works almost as good as the OEM controller in my F250.
Since your truck has the 7 pin round connector, the wiring is under the dash. Most retailers that sell the controllers also sell the adapter that will plug right into the OEM wiring.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
MISC PALLET OF MERITOR AND BENDIX BRAKE SHOES (A55745)
MISC PALLET OF...
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
MISC PALLET (A55745)
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
