no gas from fuel tank ??
   / no gas from fuel tank ?? #11
If it runs for a while then dies of fuel starvation it could be a blocked vent in tank that will cause a vacuum in tank and stop fuel flow... Check tank vent, usually in gas cap...
Dale
   / no gas from fuel tank ?? #12
Loosen (do not run with gas cap off) the gas cap. A twist to lock in place cap should be able to remain in safely with a 1/4 turn loosened which should prevent the cap from sealing thus allow it to vent past the seal. If it runs fine this way, replace the cap with a venting cap.
If the issue persist, check your fuel lines for their integrity.
   / no gas from fuel tank ?? #13
I would bet the fuel pump;my 25HP Kohler has one on the engine itself;fairly inexpensive.Also check the fuel filter.
   / no gas from fuel tank ?? #14
Check for collapsed fuel lines! Ethanol based fuel just destroys them from the inside out.
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A55788)
2015 Peterbilt 337...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2017 MACK CHU613 FLAT TOP SLEEPER (A54607)
2017 MACK CHU613...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
