No glow plugs needed at 10 degrees F
   / No glow plugs needed at 10 degrees F #11
Ocer,
Put a test light on one of your glow plugs and run the other side to ground and leave the hood up so you can see the test light when actuating the switch.
You'll find that the glow plugs are actuated BETWEEN "on" and "start" position with the gearshift lever in "N" and the PTO switch off. Without a glow plug light though, it's virtually impossible to stop in that position between "on" and "start". So, easiest way is to use the gearshift lever or PTO switch with the switch in "start" position. This actuates the glow plugs.
You may have been inadvertantly going a little past "on" in one of your turns to "on" position and have actuated the glow plugs a couple seconds or so. In really cold weather, it'll take 4 seconds in order to start without some cranking.
The owner's manual leaves this stuff completely out.
Since glow plugs last 23 years or about 200k+ miles on Benzes, they're A LOT more economical to use in starting than cranking to warm the cylinders. Our 24 year old Benz literally starts IMMEDIATELY when warm or after using the glow plugs the required amount (designated by the glow plug light going out). Even our older 1972 did this after sitting for 9 MONTHS. I just put the battery back in, glowed for the required amount of time and turned to "start". One thing I like about diesels; the fuel doesn't evaporate upon sitting for long periods of time. Neither of my 2 fuel-injected gas engined cars will start with practically no cranking, like the old 24 year old Benz diesel.
Ralph
   / No glow plugs needed at 10 degrees F #12
AndyMA said:
My TN75D starts at 0 with no assist and no block heater. Same thing less than 1/2 second. BTW, the TN's don't have glow plugs. They have a Thermal Assist which heats up the fuel if you push the button.
Andy
Andy:
If I'm not mistaken your TN75 has an intake pre-heater.
Andy
I have never used the thermal assist.
Bob
   / No glow plugs needed at 10 degrees F #14
Mine always started without glowplugs too but she sure starts easier now that I know how to use them :eek:
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2014 Ford Escape (A50324)
2014 Ford Escape...
