No hydraulics Kioti 1914
   / No hydraulics Kioti 1914 #1
stinkypete
Ive cleaned hyd filter and had the pump tested at a hyd repair shop . Pump is ok with just minor normal wear. I checked the suction line no problem there. Took relief valve apart and shimmed behind the spring but no improvement.
Ive turned the directional valve every way possible and nothing. Anything Else? Thanks for your responses .
   / No hydraulics Kioti 1914 #2
I can't assist with the hydraulic problem you're having. Just wondered why you started a separate thread from this one /forums/images/graemlins/crazy.gif It's the same problem, right? It's usually easier to keep all the related messages in one thread.
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
1989 TRAILMOBILE 45X96 SPREAD AXLE FLATBED TRAILER (A53843)
1989 TRAILMOBILE...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
