No mid pto on JD3720
   / No mid pto on JD3720 #1
Steuny
Can I install a PTO mid mount kit on my JD3720.
   / No mid pto on JD3720 #2
Yes, it can be added.
Any idea on cost and whether I can do it myself or does it have to be done by a dealer.
   / No mid pto on JD3720 #4
Cost is around $300 or so? You would have to confirm that at the dealer...
I help a friend install one on his 4400, which is similar to your 3720 I think. It's a big job-but doable if you have the mechanical ability.
   / No mid pto on JD3720 #5
There is or was a Deere PDF on the 3x20 mid-PTO install somewhere on this site. The documentation probably comes with the kit. As I recall, it was a several step process, but doable if you can follow instructions and have a minimum of mechanical skills.
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A54865)
2015 Freightliner...
