stevenf
Platinum Member
btolle you are entirely correct that if they have or eventually figure out a way around executive rights to the surface that the title policy would only give you what you paid to insure which best case is what the property was worth when you bought it. And absolutely you could lose or would lose any improvements and current value. I should have made that a lot more clear. As for the member that does not own any of his mineral rights and probably didn't have the executive rights on his closing paper work. That is the reason for the executive right insert into your contract if you don't control all surface right activity the mineral owners can (usually with notice but not always required) come on to your place and drill for oil, water, strip mine it, mine the gravel out from under it and many other hard to believe but true activities. Depending on how your paper work reads they might have to pay a little something for the use or fix anything they break or change but by and large if you don't own the mineral rights there is nothing that you can do to prevent it.
Steve
Steve
