Oil & Fuel No oil getting to oil filter
   / No oil getting to oil filter #11
gt14 said:
Thanks for the advice. But I now have the engine taken off some many parts from the motor I might as well keep going.
Keep going and do what? You may not even have a problem.
   / No oil getting to oil filter #12
gt14 said:
Tractor has a oil light but no pressure gauge. Oil is filled a beyond the dip stick level. I took oil pan off and cleaned the suction screen (Suction screen wasn't clogged but I cleaned it anyway). Cranked 30 second no oil. I removed and cleaned the oil valve behind the filter. Cranked again with decompression engaged. No oil. I then removed the oil valve behind the filter and cranked it without it or the filter on no oil. Took off the oil inlet pipe crank a little still no oil. Sounds like I have a oil pump problem. I have never tackled a oil pump any advice or cautions? Thanks Dan
The oil pump on your YM165 is driven by the camshaft and is on the rear of the engine, you have to remove the flywheel to get to it. If you want to check the pump when you get it off e-mail me and I will look up the specs for you. A new oil pump is $ 200.00 +
Danny
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2017 Rockwood Pop Up Camper (A51694)
2017 Rockwood Pop...
