No Spark on 1949 Ford 8N
   / No Spark on 1949 Ford 8N #31
I so glad to hear the good news... nothing like tracking down a problem to resolution.
Admire your tenacity because the last thing most would want to do is be outside in winter working on equipment.
Always appreciate the followup because it helps many...
Thanks, I appreciate that. I'very learned tons by following others' problems on here as well.
   / No Spark on 1949 Ford 8N #33
Isn't power suppose to go to the coil first then when the points open the power goes to the plug through the rotor button, maybe see if the coil is getting power frist.....
Electricty doesn't work that way. If there isn't a complete circuit thru the points AND the coil, nothing happens.
I had a problem with ignition on my NAA for a while. I finally realized the ignition switch had high resistance. I replaced it and solved the problem.
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2015 Volvo VNL 64T (A53473)
2015 Volvo VNL 64T...
377811 (A48836)
377811 (A48836)
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
