No Start No Crank issue
/ No Start No Crank issue #1
Yopperdog
Colorado Springs, CO
Do Not
I am brand new member to TractorByNet and am looking for some Help. I'm out in Colorado and used my tractor four days ago to clean out my Horse paddocks and it ran like a true champ. It is a JD 4400 series (37hp). When I came back from a short vacation went out to start it up and when I turn the key (absolutely) nothing happened. No crank, no effort to start. Checked lights - all worked, dash lights came on etc - battery is charge up. I've ordered a thermistor for it and waiting for it to come in. If it is not the thermistor - any other thoughts on what it could be????
Thanks everyone.
/ No Start No Crank issue #2
Check the seat switch and if the gear/PTO levers are not slightly out.
And Welcome to TBN!
/ No Start No Crank issue #3
G'day Mate and welcome (your first post) to TBN from Downunder.
Sometimes the Low/Neutral/High range selector 'looks' and feels like it's in the Neutral position (which you need to be in in order to start) so you could try re-positioning the lever.
Also, when you turn the key to 'ON' but not yet to 'START' can you hear the fuel solenoid "clicking"?
Enjoy the site.
/ No Start No Crank issue #4
Checking/cleaning ground cable to frame connection may help
Well walked out today to feed horses and decided to double check a few things on the tractor. PTO etc all good. Fuses all good. pushed in the reverse and forward pedals (HYDROSTAT). Put key in and turned to on position - heard fuel solenoid click and turned to start and it started right up and purred like a kitten????
/ No Start No Crank issue #6
Welcome to the forum! :wave:
I'm going to move this thread over to our John Deere section.
/ No Start No Crank issue #7
You might also pull battery and have napa do a load check on it. I have had batteries recharge while sitting overnight. But my guess is either a safety switch not setting properly or a loose ground. Since you fiddeled with all controls, im leaning towards safety interlock.
/ No Start No Crank issue #8
Or a reverse/forward pedal was sticking and not moving back into a neutral position for starting.. happened to me when a stick lodged tight causing that problem.
Lubricate the pedal joints where possible, in hopes it stays fixed.
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
2005 DYNAPAC CA152PD PADFOOT ROLLER (A67714)
2005 DYNAPAC...
PORTA POTTY (A67714)
More Info coming soon (A66738)
More Info coming...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
