Oil & Fuel No tax diesel fuel
   / No tax diesel fuel #41
</font><font color="blue" class="small">( There is NO difference between "off road" and regular diesel...they are the same product.....NO higher sulfur content diesel is being refined in the US....The only difference is that "off road" is dyed with AR dye...Automated Red dye....same stuff that makes transmission fluid red....colored red to help the inspection stations find tax cheats....BIG fine....if you are caught.... )</font>
I retired from from Sentinel Transportation (Conoco's Transportation Department) right at the time of the Conoco/ Phillips merger. Our terminal was servicing the Lake Charles La. refinery, supplying crude oil, and trucking out the finished products; motor oils, gear oils, off spec diesel, AND the high sulphur diesel. When Big Brother EPA mandated that "on road" diesel have a low sulphur content, it would have cost major big bucks, and down time, to enable the refinery to produce the low sulphur fuel. Can't speak for now, but back when I was working, when our terminal needed fuel for our shore tank, we had to hire an outside carrier go to the nearby Citgo refinery and pickup a load. Could not chance anyone seeing a Conoco truck loading up at Citgo.
   / No tax diesel fuel #42
The local station where I get off road diesel.
Big sign on the pump says
OFF ROAD FUEL ONLY
HIGH SULFER DIESEL
Apparently high sulfer off road diesel is still available here.
   / No tax diesel fuel #43
Tractorlegend,
I am getting into off-road diesel this weekend. I picked up the barrels for free (one time used as JD hyguard) and checked for off-road diesel here in Sumner. Today's price is 2.40 for red diesel vs. 275-2.90 for on-road, they sell tons of it and will sell me any quantity so long as I don't fill jerry cans with it. No paperwork, accounts, or hassle at the Snider Petroleum just off of highway 167. I plan to pull in on Friday morning and fillup each 55 gallon barrel to about 30 gallons so that I can move them around. May combine the barrels once they are in place to keep a minimal head space.
Barrel pump from harbor freight in Tacoma for 20$.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
