no-till drill and fescue
   / no-till drill and fescue #1
Phred
Arkansas
TN70D, 4wd, 16x16 trans
Guys,
Found a used overseed drill designed for no till overseeding for pasture renovation. Great planes and land pride (same compamy) make these.
http://www.landpride.com/lp/products/os15_specs.html
Question is: I have read several seed companies claim that fescue does not germenate well, compared to other types of grass, when its drilled in rather than broad cast seeded.
Anyone have any exeperince with this issue?
Thanks.
Fred
   / no-till drill and fescue #2
Hi ya
i have been no till seeding for a few years now and have heard this but never seen any miss fires with drilling it ,main prob is most people try to drill too fast and too deep ,i also had a look at the drill ya talking about and they are good drills BUT i'd see if i could get row spaceing closer 7.5 is ok for grain and crops but can let alot of weed grow between rows i'd look for 6 inch rows ,check this drill out
http://www.aitchison.co.nz/rancher.html
i have one like it only bigger running costs are next to zero and ya find good strikes of seed by useing a "T" boot (it makes a cut like a upside T )
catch ya
JD Kid
   / no-till drill and fescue #3
Phred
I own a landpride OS 1548 overseeder. I do alot of fesque and it does a great job. I do have the front roller and a slit seeder attachment for mine. the same depth 1/4" is very important and the slit seeder put s the seeds in the rows 2" apart. the rear roller closes the soil for good contact. I mainly use mine for yards and lawns. if your existing grass is there but needs thicked up a OS will work fine. if your bare you won't be able to get enough seed in the ground, even if drilled 3 diffent dierections. If you aplly too much seed the slot in the ground will be full of seed and will kill it's self out. I hoped I helped
DDT
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Landoll (A50657)
Landoll (A50657)
3 pt Aer-Way (A50514)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
2002 New Holland TN75S 4X4 Loader Tractor (A51243)
2002 New Holland...
