No-till drill opinions.........
   / No-till drill opinions......... #11
Our first no-till drill was a Haybuster 10'. It was used on a lot of acres drilling anything that could be run through it. If you are seeding crops to chop on ground that has had previous crop chopped off, penetration will be tough. A John Deere would be best bet if soils are hard from all of the traffic in this case. If ground is not to hard, the GP or HB will be fine. Unless HB has changed there feed system, I like the JD or GP feed system better. Around here you mostly see JD or GP. You might also check into using a Aerway aerator for no-till and pasture ground for loosening top compaction. Excellent tool to aerate and get water to absorb. We really like ours and ground drills nice behind it.
   / No-till drill opinions......... #12
It is like this if someone claims against you, the judge asks how wide was you load. If you are 6" over 10' you will lose because then you have to prove you had an escort with rotating lights, wide load signage, & slow moving vehicle signs. If you have more than 4 autos behind you, you are required to pull over and let the traffic go by or you can be ticketed. 2 problems with that is there are no many places to pull off and you are only doing 15-20 MPH being pulled by a tractor so it takes time to even get to pulloff spot. Too many tree huggers.
Might be a tree hugger or two in that bunch - but - in my experience it's all those idiots that grew up in the middle of concrete and asphalt and don't have the common sense God gave a goose!! :mad:
I'm late, I'm late, gotta get there, gotta get there... where's my Blackberry, my iPod, my iPhone, my laptop, my portable DVD player, my portable GPS, my color display GPS on the dash.... PLUG-IN-PEOPLE! :eek:
AKfish
   / No-till drill opinions......... #13
Around here width on farm equipment does not matter as long as it has a slow moving sign. The safety course I have taken also train to only pull over if you can fully get off the road, like at an intersection.
   / No-till drill opinions......... #14
AKfish
Traffic is a problem that seem to be getting worse. I not only use blinkers if I have them but also hand signal and I still have people pass me when I'm about to turn left. Or better yet pass me near the crest of a hill, had a few close calls the past few years. A few times I can see traffic coming the other way so I pull into the center of the road to prevent them from passing. Some realize why I did what I did, a few others let me know I'm #1 in there eyes. I even just had a guy pass my truck on a double yellow line when I was about to make a left hand turn onto a side road.
   / No-till drill opinions......... #15
Hello, first time poster here who was referred to this site by a friend who reads it regularly.
I'm looking for opinions on no-till drills. I'm a cattleman and the drill will primarily be used for pasture seeding, establishing winter grazing, and planting silage crops (round bale silage - millet, sorghum). There are two primary options right now, Great Plains and Haybuster.
I'm looking at the 1006NT Great Plains and the 107 Haybuster. Prices are both right at $22,500, and both dealers (Great Plains thru the Deere dealer, Haybuster thru the Ferguson) are about the same distance from the homeplace and offer good service and support. I have an established relationship with both (Deere tractors, Krone baler from the Ferguson place) and would feel comfortable buying from either.
I've been renting a no-till drill, a TYE, and it's a solid drill but my operation has grown to the point where I can't wait around when the drill is out to another customer, and I like the TYE, but there isn't a local dealer.
Any experiences with either of these drills?
Is your local MF dealer not a tye dealer? Usually ever MF dealer is a TYE dealer, or at least carry the parts. I have a really nice TYE 8ft drill for sale at my store. Its a pull type or 3pt. It has both seed boxes, big and small.
And best of all its over 14,000 less!!! We are in NE Alabama. If you are interested feel free to call us. 256-927-5454.
   / No-till drill opinions......... #16
I work at GP, so consider my brand loyalty. if width is a problem, there is a 3 pt version of the 10' no till(3P1006NT). Also the 1007NT has no end wheels. On the plus side there is an R&D department that is always looking for ways to improve the product.
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
