No voltage to coil cyl#2 on JD L120
   / No voltage to coil cyl#2 on JD L120 #1
sjs12307
winston salem,nc
L120
Running on one cylinder. Is this a safety switch issue? Coil shows no resistance and there is no voltage to the coil and there are no problems with the wire as it crosses the motor. The connector further downline shows no voltage to this wire either.
   / No voltage to coil cyl#2 on JD L120 #2
Not a safety switch issue. Unless you are running one of the bigger Kohlers with spark advance, you don't want any voltage to the coils. It will fry the modules on the Briggs, or Kohler either one. Disconnect the wire going to the modules, and check for spark, if no spark replace module. The wire connected to the module is a kill grounding wire only, not voltage.
Thanks, gonna try with wire disconnected.
Dang, new coil makes a new mower :) thanks Randy.... just a few new senior moments logged.
10-16.5 SKS1 Tires (set of 4) (A49251)
10-16.5 SKS1 Tires...
2007 Amkus Rescue System (A46683)
2007 Amkus Rescue...
2009 BMW 750i Sedan (A46684)
2009 BMW 750i...
2018 Komatsu WA500-8 Articulated Wheel Loader (A46683)
2018 Komatsu...
2017 Toro GroundsMaster 7200 72in Zero Turn Mower (A46684)
2017 Toro...
Woods 3pt Side Bank Mower (A49251)
Woods 3pt Side...
