noise cancellation headphones
   / noise cancellation headphones #11
I just use the "noise canceling" (not really) ear buds and hearing protection over that. They aren't real noise canceling but they fit in the ear like ear plugs so that helps muffle sounds. If I put on my large ear muffs I can drown out just about everything but if I want to continue to hear the tractor a little I use my smaller ear muffs. You just got to be really careful because you can totally block out almost all external sounds with the right combination of the two and that isn't safe imho. The ear buds are a much cheaper options and you can get some pretty good sounding ones. They will never sound as good as the mid range over the ear headphones but if I accidentally destroy them I can replace them several times before I reach the price of the expensive over the ear headphones.
   / noise cancellation headphones #12
"No highs, no lows...must be bose"
   / noise cancellation headphones #13
I've got two pair of the 3M Bluetooth Worktunes. I liked my first set so much I got a second for my home shop.
I used to wear earbuds and the cord kept either getting pulled out of my phone or pulling my phone out of my pocket. No more of that nonsense! :)
   / noise cancellation headphones #14
Bose QC35 Bluetooth have worked very well for me 1+ years now. Better than the Sony in ear and on ear noise cancelling headphones I also owned. Expensive but worth it. Don’t buy On-Ear units, they don’t block incoming sounds well and are less comfortable
   / noise cancellation headphones #15
I use the 3M Worktunes with Bluetooth. Have tried corded version - never failed would snag that cord on something and pull it out of phone or earbud out.
Did test the Bose headsets. Definitely better sound quality. But listening to audiobook, podcast, etc on the tractor the background noise will eat up the difference. The 3M are more robust. Probably would have broken those $350 Bose by now.
The Worktunes don't have a microphone. But a phone call will interrupt the Bluetooth audio so you know the phone is ringing.
   / noise cancellation headphones #16
I've had several sets of cheaper noise cancelling headphones. They seem to be tuned to aircraft noise.
Other than targeting noise in a particular spectrum, which is the auditory hearing range of humans, these headphones are not tuned. But they do work best with a constant noise rather than noise that is changing in volume and pitch.
One other thing is that they do not cancel noise, which is impossible. They identify incoming noise and then emit counter-noise to offset what is already coming at you. I've searched for years to learn whether the noise+counternoise combination is more damaging to your hearing than just the original noise to start. We all know it seems quieter. But is there more or less vibration on your eardrum?
   / noise cancellation headphones #17
I guess it depends on your definition of "less vibration". You have less amplitude at certain frequencies with active noise cancellation. In theory, if you have perfectly synched and opposite wave forms then you have zero amplitude at those frequencies. In reality you are never perfectly synched. I think that amplitude is more destructive to hearing vs frequency. With higher amplitude at a certain frequency you are transferring more energy.
Google principle of superposition.
   / noise cancellation headphones #18
Over the ages I have tried numerous different noise canceling headphones, and feel they are all (including Bose) oversold on performance. For tractor use especially, they don't seal out enough noise nor do they "cancel" like advertised. I prefer to use, like MercDV, wireless ear buds under industrial strength ear muffs. That has been what I found to work the best.
   / noise cancellation headphones #19
Bose Noise Canceling. Gotta say that the cost of the best noise cancleling headphones sure seemed much more acceptable after my hearing had been damaged and tinnitus began.
rScotty
   / noise cancellation headphones #20
The thing I like about the Bose (I have the in ear, not over) is that you can adjust the level of pass thru. I let it do as much cancelling as it can while running the machine, then dial it back so I can hear my surroundings while off. Love them!
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
MISC CABINET PARTS (A54757)
MISC CABINET PARTS...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
