Noise Levels how high? 90-110?
   / Noise Levels how high? 90-110? #11
</font><font color="blue" class="small">( If we're going to compare notes we should also be careful we're measuring roughly the same way - "A" or "C" scale, and the position & orientation of the meter. )</font>
Excellent point! I went back today and tried it again and got 95db on A weighted and 104 on C weighted. Don't know what the difference is, really. I tried it on fast and slow response but that didn't matter either way.
   / Noise Levels how high? 90-110? #12
Bob - the "A" and "C" sensitivity ranges weight the relative importance of different frequencies differently. "C" is a flatter curve (but not perfectly flat) while the "A" range de-emphasizes the importance of lower frequencies. There are more curves "defined" but most less expensive meters typically only cover A or C range. I believe all the curves are supposed to be equally sensitive at 1Khz. I had thought that the A range was supposed to roughly mimic human hearing but reading this from OSHA only complicated the issue:
OSHA Occupational Noise Exposure
I'm not sure I'm interpreting these guidelines correctly - but bottom line you've got to get your sound level exposure down under 85db (from whatever the actual level is) using muffs or plugs or it's going to cause long-term trouble. Some days it seems like I'm the only one in the family now who doesn't reply "Huh?" everytime someone says something - I want to keep it that way! /forums/images/graemlins/grin.gif
   / Noise Levels how high? 90-110? #13
</font><font color="blue" class="small">( Bob - the "A" and "C" sensitivity ranges weight the relative importance of different frequencies differently. )</font>
Thanks for the great info! As far as the hearing protection is concerned, I had already come to that conclusion. It's muff style protection for me while tractoring. /forums/images/graemlins/cool.gif
New Holland Workmaster 255 Tractor (A57453)
New Holland...
Electric Concrete Mixer (A57453)
Electric Concrete...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2017 Ford Fusion Sedan (A56859)
2017 Ford Fusion...
Forklift (A59228)
Forklift (A59228)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
