I would like to ask those of you who have experience with the hydro transmissions. I have a B7510 and it makes a strange noise as if some bearing had some problem in there. It happens when there is no load on the engine such as when the tractor got up to speed after pushing down on the pedal or if I coast down a small hill with a the pedal down a bit. I tried it from 1500 to PTO rpm and it happens at any of them. I'm not talking about the whiney noise the hydro makes or may be it is a different kind of noise that supposed to be there. It kind of sounds like a worn out power tool that has a worn axle bearing/bushing. I wonder if that is normal or I should be concerned about that. It has been happening for a while even when the engine and tranny get warm. The tractor always runs for at least 5-10 minutes before I even move it and I like it to be running for about 15-20 minutes total before doing any work with it. I do not notice any difference in power or performance. As a matter of fact it does not happen when I work the machine because there is always load on the transmission. Could you give me some pointers here?
Easygo
Easygo
