Noise under my hood....
   / Noise under my hood.... #1
ozsevenzero
Massey GC 2610 TLB
I got a GC 2610 that has roughly 26 hours on it and it recently started making a whirring type noise whenever the tractor is getting some above average bucket or backhoe use. Happens especially in 4wd. Possibly low on hydro fluid. I haven't taken off the BH to check cuz i used it so much in the past few days but i am thinking that has something to do with it. Thoughts?
Also, has anyone ever used Rhino Liner, Line-X or Reflex liner on their hood. I am constantly pushing brush and what not with the bucket and have some dings and scratches.....was thinking about spraying the front quarter of the hood to protect it somewhat. I have a buddy getting his bed sprayed and the guy said he would knock it out for under $75 bucks.
   / Noise under my hood.... #2
The hydro pump is in the rear of the tractor. Does it do it when the tractor is stationary? Reason I ask is you say it happens in 4wd. How long is it running when it starts? Any leaks? Does the sound change when you change the RPM? I would check all the fluids to be on the safe side. It doesn't take very long to remove the BH. You could buy on of those mechanics mirrors on a long reach rod, and shine a flashlight to see the level of the hydro.
As for the Rino liner, should work, price is a little steep. You could go to a autoparts store and buy a small can and do it yourself for around $20.
   / Noise under my hood.... #3
Look up underneath the tractor, locate the shaft that goes from the engine to the transmission.
On the back of the shaft, there should be a 'fan'.
Sounds like something got into it.
Any blades missing?
If so, replace it.
EDIT: Also check under the hood, a stick or something could have gotten to a place it shouldn't be.
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
1272 (A50490)
1272 (A50490)
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
