Not a John Deere but ooohhhh what a toy!
   / Not a John Deere but ooohhhh what a toy! #1
Barely Smokin'
Nelson County, VA
1952 JD 440 backhoe, JD 790
Sorry, guys, had to share this. Just picked it up today. It's a 1977 Caterpillar D4D, weighs in around 22,000 pounds. Starts on the first revolution without a block heater! Runs like a dream. Drivetrain is 95%, aside from the grouser pads, which are fine. No leaks anywhere. All fluids perfect. Bought it from a service manager for Hyster for about 1/3 of what I paid for my 790. New muffler, new seat, and a coat of paint are all she needs.
Plus, she's got a PTO winch on her that could probably alter the orbit of the moon. Should be fun!
Let's just say it will pick up where my box blade leaves off!
   / Not a John Deere but ooohhhh what a toy! #2
Congratulations on your new find, just remember dozers can get stuck too, then you are really stuck. I think I would add a muffler to it so you can hear everything and run it for awhile and see what you have. Good Luck with it;
Thanks, Jenkinsph. I've got a good feeling about this one. Anything that starts as good as this one, and has hydraulics that work this well, and steers, etc., is off to a good start.
   / Not a John Deere but ooohhhh what a toy! #4
Good luck with your new toy! , As a heavy equipment operator by trade i spend alot of time on cat stuff and the older stuff is built better then the new! The other guy is right about getting it stuck ! If you dont have other iron to dig it out think twice about the really wet spots , ( although you do have a winch) ??
Thanks, Kevin. Yep, I hear the D4D is a solid machine. I like that older iron myself. I'm stoked.
I don't have anything that would touch this dozer if it got stuck. First order of business is to get a hundred or so feet of 3/4" cable on that winch so I can go play! I understand the winch is oversized for the dozer and will pull the dozer up just about any grade...or out of any hole...
   / Not a John Deere but ooohhhh what a toy! #7
And you thought you were able to get yourself in trouble with your John Deere !!! ;);)
   / Not a John Deere but ooohhhh what a toy! #8
Very nice find- you will enjoy the D4!!!! :D
Thanks for sharing your photos!!
   / Not a John Deere but ooohhhh what a toy! #9
I'm jealous! I know it is a very capable machine because I've rented one a few times (one week rental at a time) to clear stumps and smooth out terrain here on this old farm. About had a coronary a couple of times when it bottomed out in very soft ground and got stuck. Just have to be careful but like you said it will do well in picking up where your smaller implements leave off. Good luck with your new toy.
   / Not a John Deere but ooohhhh what a toy! #10
you lucky dog im jealous
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
New Holland...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
New JMR 40" Mini Skidloader Flat Bottom Grapple (A50775)
New JMR 40" Mini...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
