Not sure how many responses I'll get, but...
   / Not sure how many responses I'll get, but... #91
There's always something better than what you have. If not, just wait a year. :D Every aspect of every tractor can be improved. I'm extremely happy with my Kioti LB1914 and think it is one of the best values on the market if you're looking for something in the SCUT to Small CUT range for ground engagement or forestry. But if you're looking for a mower, you'll want more hp and less weight.
Personally, I don't see any advantages of a SCUT over a small CUT except for price and weight unless you need to get under really low stuff. The big difference is tire size and ground clearance. In snow, mud, or the forest, big tires and lots of ground clearance will get you a lot further.
Bottom line:
For ground engagement / forestry go as big as you can based on the limitations of your wallet considering storage space and access requirements of your property.
For mowing go high hp light weight.
As a previous poster stated. You have to know what you want to do!
   / Not sure how many responses I'll get, but... #93
On my 2660 it's two things... one, it's not a B3030 and a zero turn. Two, the 3ph control lever is low enough that I have to lean forward to reach it. If I'm twisted around watching the box blade, it's a pain to reach the lever. There's an empty slot in the control panel up high. I wish I could relocate that lever there. It would be a lot more convenient.
Ian
That slot has symbols for a hydraulic control lever on the BX1500, perhaps for a remote. They didnt follow thru on the design and chose instead to kluge it up on add ons, hanging valves and control levers off the tractor in places more easily damaged in use.:mad:
larry
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2015 WESTERN STAR 4900 SF (GLIDER) DAY CAB (A53843)
2015 WESTERN STAR...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
FORD F150 TRUCK (A54756)
FORD F150 TRUCK...
METAL FILING CABINET (A53843)
METAL FILING...
2013 MAXEY TRAILER MFG UTILITY TRAILER (A53843)
2013 MAXEY TRAILER...
