Not to beat a dead horse, but.......
   / Not to beat a dead horse, but....... #11
Tractors4u said:
Snip... having the pedal to the floor would be the equivelant of having it in high gear. ...
In that case, would it not have loaded or stalled the engine? It seems his problem was no matter where the pedal was, the engine did not load, stall, nor spin tires. That was a problem I had which turned out to be in the Hydro. It would loose pressure when the pedal was pressed.
I say have your dealer look at it.
I agree. Although I do not fully understand the inner workings of a hydro, it seems to me that as the engine had more load applied to it, it would have reacted accordingly. I took the slack out of the chain slowley and then I slowley "floored" the pedal. The only thing I noticed was an increased whinning from the hydro which I would assume is normal. It may just be that it is not designed to pull that kind of load and if thats the case, I can accept it. However, if it is not reaching it's design limits, then it bugs me. I'm not quite sure when I will get it done, but I think it's gonna go in for a look see.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
1272 (A50490)
1272 (A50490)
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
