ljh2
- Joined
- Jun 5, 2001
- Messages
- 282
- Location
- Western Maryland
- Tractor
- Kubota M6800, Ferris IS4500Z Cat Diesel mower
Laminarman,
I'm sure that your TC40 should have no problem pulling a 2 bottom plow. I'll agree with Egon and Cowboydoc that you would be better off working the soil and applying the neccessary amendments (lime and fertilizer) to improve the soil. I'll also agree that a 'green manure' crop will make a great contribution to your soil condition.
I'd definitely suggest that you walk the area well though and mark any rock outcroppings that may prove to be immovable so you don't damage your plow though. Plowing at around 4mph will turn over the soil nicely, but will bend your plow frame if you hang it up on a protruding bit of bedrock. /forums/images/graemlins/frown.gif
If you have a potential run-off problem, be sure to leave a green-space catchment area to contain your soil and practice contour plowing where neccessary.
Chemicals like Roundup have their place, but if you are going to turn the soil, you'll be better off turning that GREEN matter under to recapture the nitrogen and minerals. Also like Egon said the seeds already present won't be affected by the Roundup, and if you are planning to plant seed here, you don't want to apply a pre-emergent chemical.
The TSC guy wasn't giving you the best of advice. /forums/images/graemlins/crazy.gif He wants to sell you a lot of expensive chemicals and extra seed.
Get yourself that 2-bottom plow and a 7' lift disk and tractor on. /forums/images/graemlins/smile.gif
