Now What?
   / Now What? #11
I have a 5525 which is about a year & 1/2 old (60 hours) and it has just started having dash problems. I sometimes have to knock on the face of the panel to get the temp or fuel needle to register. My tach reads normal most of the time but occasionally reads about 300 RPM higher than it is running? Sounds like this is common.
DB
   / Now What? #12
Just a thought here folks. Is it possible your instrument panels are not properly sealed from dust and moisture? Both of those contaminants can affect electronics.
   / Now What?
Mine only had 26 hours on it. But it likely did sit out in the weather for month before I bought it. The new one was right out of the pakage so I don't know what going on there. But the dealer seams like they will take care of it.
   / Now What? #14
New tractors sit on the dealer lot without any protection from the elements and the manual doesn't say that you need to store them in a garage. My opinion is that all tractors including instrument panels should be designed to live their entire life outdoors.
DB
   / Now What?
Talked with the dealer today and the rep is sending a new one from the factory that they tested to be working. It should be in Friday. I'll keep you all posted.
   / Now What? #16
Did you ever get a resolution to your Tach problem? I have a brand new 6530 with less than 7 hours on it so far and I've caught myself having to tap the tach to get it to work. I can only think that's off to a bad start.. Also had a mystery starting problem. Acted like the neutral safety switches were acting up. I tried all teh usual things like shifting it in and out of gear, up and down the Hi-Lo, in and out of gear on the PTO. Also hand operated the PTO safety switch, then it just as suddenly decided it wanted to start again. Never had that problem on any of my other tractors, although my only experience has been about 30 years of dealing with old big tractors, other than a short term deal with a JD 4400 Which drove me to swear never to buy anything green again, which is how I ended up with the Mahindra.
Jim,
Follow your ground wire from the battery to where it is attached to the frame, engine block. Check this connection. I have seen and heard of quite a few people complaining of the same symptoms and it turned out to be a bad ground.
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
KOMATSU WA500-8 WHEEL LOADER (A60429)
KOMATSU WA500-8...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
