Well, lots of good reading.
Well your tone gives me a feeling that you just haven't quite put it all together yet then. It's
technically true that valve lash and head bolts aren't mentioned in the Chinese engine manuals until 100 and 500 hours respectively. But then take a look at when those manuals were last updated. The one in front of me right now says Oct 10th, 2000. That's why these forums exist. In the 10+ years since, there's a lot of dealer and user water that's gone under the bridge. During that time, the same mechanical issues kept arising in otherwise "new" tractors. High on the list were (a) dirty fluids, (b) parts falling off, (c) clutch problems, and (d) blown head gaskets. Hence, the collective wisdom came up with a maintenance list that is NOT in the books. You can find hundreds of references to it as the "
50 hour (break-in) maintenance".
And since the valve train comes off for the head bolt job, it only made sense to do the valve lash adjustment at 50 hours instead of the 100 hours recommended in the book(s). The manufacturers
500 hour valve maintenance by the way, is a lot more than just valve lash. It's grind & lap first,
then reset valve lash. If you never touched the valves before then, you might not even MAKE it to 500 hours.
Ignoring such hard learned lessons so generously contributed by our members - is done at your own expense.
//greg//
