NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #11
Can anybody click on the link the OP posted and get to it? I have been getting lots of links redirected to some vigilink page. Some work and some don't. I have noticed all links to Agri Supply get redirected. Have they banned all but sponsored links?
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #12
Can anybody click on the link the OP posted and get to it?...
Yes, no problem here... I run Firefox with Ad Blocker Plus, Ublocker and NOScript. No ads and no problems...
Good news is you are generating money for TBN... me, not so much.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #13
I've mentioned this on other related posts. I've tried most of the cheaper' super siphons' and 'gas gizmos' and whatever and finally give up and bought a 12volt Fill Rite pump Fill-Rite Home Page - FillRite
to do the job. I mounted the pump to a bench in my gas shed and installed a flexible pick up hose to the bottom to insert into 5 gallon cans of either gas or diesel. I don't go thru a lot of fuel in my toys as compared to a commercial operation and it's easy to bring home what's needed in 5 gal cans. Good for lawn equipment , tractor, ATV and snowmobiles. I recently bought another small pump called 'The Pocket Pump". Pocket Pump.ca for $30.00 and am very happy with it so far. Runs on 2 D battery's and good for smaller fill-ups like lawn mower and chain saws. Almost no spill.
Al
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #14
My concept for it's use is primarily refilling tractors w/FEL's
Fill it up in the pickup bed, roll , put it in the bucket, store it. Put it back in the bucket, lift and siphon into the tractor.
I'd say elevation for gravity feed is key with these. I use a cheap 3 or 4 sheave manual rope hoist in my garage to lift mine.
The nozzle is definitely consumer grade. Mine has stood up for a few years of occasional use, but I'm the only one using it, and am pretty careful. I use it to store generator fuel, and for vehicle emergency fuel. I only put E0 in it. With the can elevated, I only use the handle pump to get things started to flow.
This company sells the pump handles in separate hose/can adapter kits I think; that would be one way to get a replacement handle off-the-shelf if needed in a hurry.
Plan on replacing the hose, unless they've really stepped up their game (doubt it, at the price-point). Mine was a hard plastic hose (likely to stand up to E15 etc....) and was unsuitable for my climate - I don't remember the hose leaking, but it kinked so bad that the flow was reduced quite a bit - I replaced mine with a decent commercial bulk hose. Shut-off valves seem decent, knock-wood.....
I wouldn't expect the nozzle to survive with a landscaping/maintenance crew, but if you are careful and can elevate the unit most of the time, then you may find it OK for light personal use.
One thing I can say about the nozzle - if I was away from home and my wife needed to fuel something ASAP, I'd sooner her use this nozzle than a regular gas can. The one time years ago she tried refueling something on her own (outdoor maintenance/chores has always been my domain) from a can, she managed to spill gas all over the place - didn't question the event too closely at the time (she felt bad enough), but I suspect she just didn't have the regular can nozzle tightened down well enough.
Rgds, D.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #15
I run ad blocker on firefox but not the other stuff. Guess I will try them.
Just tried the link with chrome on my cell and same redirect to vigilink occurred.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #16
It is offered on Amazon (at a substantially higher price) but there are hundreds of reviews. They read about like this thread - half thing it's great, and half think it's junk.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #17
I bought the 28 gal one at an auction sale for 60.00. Best money I ever spent. But on mine it had a pump in the end standing up and I replaced that with a 12 volt fill right pump. I have a 1 inch valve at the bottom in the front which I plugged. Some day I am going to mount the pump on the wall and plug the 2 inch hole in the tank, then run th hose from this 1 inch valve at the bottom to the wall and use quick disconnects si I can disconnect the bottom line pick the tank up with my forks and take it to fill it
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #18
I ordered one from the original link and it came right away...
Looks like it will be fine, we will see how long it holds up.
SR
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #19
I've been trying to figure out a good way to store at least 2 fill-ups, or about 20 gallons of fuel for the tractor. I've yet to find a sub 60ish gallon tank with anything other than mediocre reviews.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #20
I like the simplicity, durability, and reliability of these: VP Racing 2 Pack Square Red 5 Gallon Race Gas Alcohol Can Fuel Water Jug IMCA
Five gallons is still manageable for me. Fourteen isn't. Then again, I always fuel outdoors.
For 2-cycle stuff, I have a couple of these: https://www.walmart.com/ip/No-Spill-LLC1415No-Spill-Gas-Can-1.25-GAL-GAS-CAN/38473987 I switch off with them, so I haven't run dry.
And I keep a 2 gallon can my wife can handle. Every month or so, I empty what's left into our daily drivers and refill the cans (except the 2 cycle, of course). I have a five gallon diesel unvented (CARB compliant) plastic jug with the old flex hose (non-CARB compliant) that I use for my tractor, which is my only diesel-powered machine. I get down near the empty mark on the gauge and drive up by the shop. Stick the hose in the filler, lay the can on the hood, and go do something else for a few minutes. Can will be nearly empty when I return (7 gallon tank) and I just tilt it up to drain the last of it into the tank. Next time I get gas, I get diesel too.
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2023 RHINO X1406 LOT IDENTIFIER 74 (A53084)
2023 RHINO X1406...
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
12' CONTAINER (A51248)
