Item Details
Surplus to my needs are hundreds of never used M8 x 30mm, Bright yellow corrosion plated 8.8 Grade Hex bolts with Hex nuts. These may be some kind of Chromate plating which is much better than zinc. They are stamped with "3F" which I was told represents the foundry they were made in which is Fontana Luigi in Italy.
Grade 8.8 is equivalent to USA standard Grade 5. They have a threaded length of about 1-3/8" long with hex heads that mate perfectly in a 13mm wrench. Just for fun I tried to see what USA standard wrench size would fit and I was able to JUST fit a 1/2" wrench over the nuts & bolts.
I can fit up to 150 (nuts & bolt pairs) in a small USPS flat rate box for $10 and many hundreds more in a medium flat rate box for $20. I looked at Lowe's and Fastenal for prices and Lowes was stupid high. Fastenal had generic (Asian) zinc nuts & bolts for about $1.25 for a nut/bolt pair. What about $0.40 a pair for as many as you want. Again, 150 will fit in a small flat rate box for $10.00.
