Buying Advice NX 5510 with 24x24 trans
   / NX 5510 with 24x24 trans #1
LittleBear
Middlefield, Ohio
Looking for a relatively simple and reliable tractor with at least 45 pto HP for field mowing and snow blowing -- no loader work or back and forth stuff.
I like the looks of the NX 5510 Cab with the 24x24 transmission. Does anyone have the NX with this transmission? If yes, what are your thoughts? What about simple maintenance?
   / NX 5510 with 24x24 trans #2
I have one and really like it, it just turned 90 hrs today. I do all types of work with it from discing , tilling, cultivating, mowing and loader work. I really like it, as for maintenance it's no different than any other tractor, grease all the fittings every so many hours , change oils and filters.
The more I read about it, the more I like it. I'll try and find a dealer that has an NX in stock just to see one, then I may order one. Thanks for the help. :)
   / NX 5510 with 24x24 trans #4
Somebody else here a few months back got one with the creeper gear for much the same use as you, and ended up really liking it.
Getting something with a very slow reverse speed is a must. This sounds perfect for me.
   / NX 5510 with 24x24 trans #6
The NX usually comes with a 12*12 shuttle. An option is to add a low creeper gear to each gear, resulting in 24*24.
   / NX 5510 with 24x24 trans #7
The 24 x 24 is standard on the NX, not a optional creeper.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
Bobcat T590 (A53317)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
