AxleHub
Elite Member
Max 28 was out for a while -- he got his in early 2013 if I remember right. In 2014, Mahindra de-rated the engine and now calls it the Max 26 to stay under Tier 4 Final. It's pretty much the same exact tractor but with less rated HP.
The 1026R was the model before the 1025R, and is otherwise identical -- was just de-rated to 25HP (probably for same reasons as Max mentioned above).
When you "de rate" . . Does that mean they also "de tune" the engine too. If all it was would be a number change . . . Wouldn't that be called a lie and in violation ? As a recall . . That max28 was a few thousand more than their 25 . . I wonder how that all worked out.
So the j.d. 1025r is newer than the 1026r ?
Then it certainly seems like Nikko got a very cheap bid for a 1025r with drive on mmm deck and fel. As I recall they were more in the 17500 price range.
