O-Rings for injector pump
   / O-Rings for injector pump #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
Hello all,
I have a leak on my Chinese tractor injection pump, KAMA 454. The leak is on the top side at the delivery valves. There are 3 sizes and a crush washer. I can't get parts for this, just a replacement pump.
Do you trust NAPA O-rings? Do you think just taking measurements will net the correct size? They look to be still soft and flexible.
   / O-Rings for injector pump #2
O-rings are a pain to measure. But they will most likely be metric for the Kama. If memory serves me right the napa O-rings are 70 durometer buna. Buna is good for diesel. In theory they should work if you get them measured correctly. I am guessing Kama parts support is non existent?
They sell pumps, but not parts for them.
I found a O-ring calculator at;
The top O-ring cross section measures small compared to the formula, this likely where it's leaking
   / O-Rings for injector pump #4
There is a pump rebuilder on here somewhere. Try him for parts.
I did contact thepumpguysc, he does not sell parts
   / O-Rings for injector pump #6
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
Gas Air Compressor (A50860)
Gas Air Compressor...
John Deere 370 Flail Mower (A50860)
John Deere 370...
2022 Club Car...
