O-Rings for injector pump
   / O-Rings for injector pump #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
Hello all,
I have a leak on my Chinese tractor injection pump, KAMA 454. The leak is on the top side at the delivery valves. There are 3 sizes and a crush washer. I can't get parts for this, just a replacement pump.
Do you trust NAPA O-rings? Do you think just taking measurements will net the correct size? They look to be still soft and flexible.
   / O-Rings for injector pump #2
O-rings are a pain to measure. But they will most likely be metric for the Kama. If memory serves me right the napa O-rings are 70 durometer buna. Buna is good for diesel. In theory they should work if you get them measured correctly. I am guessing Kama parts support is non existent?
They sell pumps, but not parts for them.
I found a O-ring calculator at;
The top O-ring cross section measures small compared to the formula, this likely where it's leaking
   / O-Rings for injector pump #4
There is a pump rebuilder on here somewhere. Try him for parts.
I did contact thepumpguysc, he does not sell parts
   / O-Rings for injector pump #6
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
