Off Topic--Problem With Drain Vent On Lavatory Sink
   / Off Topic--Problem With Drain Vent On Lavatory Sink #11
Questions;
Has it always stunk like sewer, or did this come on gradually over the years? When you first enter the bathroom does it smell? You said earlier in this thread you pulled the trap apart to clean it. When you took it apart was the U bend full of water? Kenmac was starting to hit the nail on the head in his post.
I'll tell you this, you could vent the whole house no problem with a 3/4" pipe. So the vent is not the problem. A vent prevents a siphon on the p trap, nothing else. So if it only stinks when draining, the vent is not the problem because the trap is always full. Here's what I would try, pour some drain cleaner in the overflow holes of the wash basin. What happens is over the years scum builds up in the drain waste line. (the part mounted to the basin itself) It continues to build/plug the overflow holes and the gasket itself will get pretty stinky along with the old dried out putty. So putting some good drain cleaner down the overflow will clear out the section I'm talking about. It never hurts to plug the drain and fill the basin to the point it overflows into the "overflow" just to keep it clean and washed out. A common problem with most drains and people is they get done washing and instantly turn of the water, not allowing any time to wash the dirt/soap/toothpaste/spit etc down the drain.
Been a Master Plumber for almost 30 years now. I could be wrong but I doubt it.:D
   / Off Topic--Problem With Drain Vent On Lavatory Sink #12
If it's been draining water and you have had no problems from 74 until now.. I doubt it's a vent problem..
Soap scum & hair will gather in the drain lines over the yrs and tend to smell just like sewage..
Take your trap apart and inspect the drain pipe
I just read your profile, when I read your post I thought "he knows what he's talking about". Now I know why.:thumbsup:
When I went through plumbing school (1985ish) auto vents were not legal, although I see them used much more now I'm still not a fan.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #13
We don't use them on a regular basis, but sometimes you have to do what you have to do.;)
The ONLY time that I smell the gas is when draining water out of the sink. This has been going on for as long as I can remember but can't say positively that it dates back to 1974. I've been putting up with it as I'm usually the only one of the family that uses this sink.
I should have clarified when saying I "cleaned the trap" that it was only using drain cleaner. (unplugger) May have to take the trap apart and see what kind of life forms may be hiding in there.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #15
That's why I don't think you have a vent issue..I'm not there to be able to inspect.. This is only my opinion
   / Off Topic--Problem With Drain Vent On Lavatory Sink #16
That has my vote too.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #17
So you now have kenmac, ozley and myself saying it's not a venting issue. I would try what I suggested above. Be careful and be creative, you'll need a flexible funnel to get the drain cleaner in the "overflow" hole. After the drain cleaner has had several minutes to work flush out the overflow good with cold water.
In case you are keeping score--that's 3 plumber's by schooling / profession.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #18
If that's what the problem is. I would use/recommend studor vent brand AAV..I have use a number of these without any issues
This^^^^.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #19
Knowing if water is in the P-trap is the key. You stated above "The ONLY time that I smell the gas is when draining water out of the sink". So I would guess the trap is staying full meaning for sure the vent is not the issue. If you were to take apart the drain on the bottom of the basin (not saying to do this) and see what's in there you would understand why I'm just saying to pour drain cleaner in the overflow hole. Just out of curiosity is the washbasin China, Cast Iron, plastic or porcelain over steel?
   / Off Topic--Problem With Drain Vent On Lavatory Sink #20
While building a bathroom in my basement the inspector that did the inspection was a plumber before he became an inspector. He advised me to put a studer vent in the drain line under the sink. I explained that the p trap wouldn't go dry as we expected to use the sink. He said the sink was too far from the vent pipe and it wouldn't properly vent so the the sewer gas would work its way up through the p trap while running the water. I'm no plumber, but there hasn't been any smelly gas from the sink when we use it. I think the vent cost me $15 at Home Depot.
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
New Holland TS6.130 4WD Utility Tractor with Slope Mower (A53421)
New Holland...
