Offset Attachment Adapter
   / Offset Attachment Adapter #1
MasseyWV
Veteran Member
Recently I was thinking about work I need to do to my driveway using my box blade when I began to think of how nice it would be if I could somehow offset my box blade by about a foot to either side so I could more easily scrape the sides of the road without getting the tractor too close to the edge of the road.
Then it occurred to me that something like an offset attachment adapter (for lack of a better description) would be just the thing to do exactly what I need without having to purchase another attachment. I don't know if such an offset adapter even exists, but it seems to me that it's at least within the realm of possibility. Thoughts or suggestions are welcome.
   / Offset Attachment Adapter #2
An even better idea would be an offset adapter capable of also transferring PTO a bit to the side... I would love to be able to use my rotary cutter a bit to one side to allow cutting along roads. But I have never seen such an animal. You can get the full hydraulic cutters as used by road maintenance crews, but they are prohibitively expensive. Just a little offset would be good.
After some additional searching, done after creating my initial post, I found the following patent for an offset adapter which seems to do exactly what you described. I thought that if an offset adapter had ever existed that someone would have surely patented it, and I quickly discovered that they had done precisely that. The only problem (in my case) is that the design (shown below) doesn't seem like it would be strong enough to withstand the stresses generated by a 6 foot box blade.
Patent US4195860 - Offset adapter - Google Patents
   / Offset Attachment Adapter #4
That would work with a mower but with a rear blade, box or regular, you would soon find yourself being spun around, at least on most cuts.
On a heavy tractor with light cuts it might work but efficiency would suffer.
Offset scraper blades do exist so I was thinking that something similar could be done with a box blade. Aside from the box blade having rippers and side skirts to contain material, there really isn't much difference between it and a scraper blade. As long as one took it easy and didn't try to use the box blade to it's maximum potential, I fail to see why it couldn't be done.
In my case, I need to dress the very edge of the road where it meets the ditch line, but would like to reduce the risk of having one of the tractor tires dropping down into the ditch, which has become somewhat deep in places. Referring to the image below, the shoulder (about a foot wide) is the area which I need to grade because it has become elevated in relation to the rest of the road and is preventing water from draining properly.
   / Offset Attachment Adapter #6
THe rear angle of the box blade's blade is significantly more sharp much more ) to it than any normal rear blade. THe other significant difference is most non-inexpensive rear blades are designed to offset, and tilt as well as rotate in order to do the job you specifically want to do.
I mean you COULD modify a rock to use as hammer, but a hammer is so much better at being a hammer than a rock... makes you wonder why you just dont use the hammer to start with.
I realize the curvature of the cutting edge of a box blade is significantly sharper than that of a typical scraper blade and that many of the higher quality scraper blades are specifically designed to do the task at hand. Why buy another implement that has to be changed to a single specific task that *could be* accomplished with the box blade, and without the need to change implements? The box blade is such a versatile tool as it is, so what is wrong with considering the possibility of adapting it to make it even better?
One could modify many things to use as a hammer, which remained basically unchanged until someone got the idea to create an attachment for a completely unrelated tool (air compressor) to make an air hammer, leading to many other inventions such as air-nailers. Or maybe the air-nailer actually came first, but that's not the point...
Just because something has always been used a certain way, does not mean it cannot be improved upon with a little creative imagination and perhaps even a little experimentation.
   / Offset Attachment Adapter #8
I agree that some sort of "offset adapter" could be very useful in some situations. It would be nice to have the ability to use when needed.
Personally, I would love to have an offset for my rotary cutter to avoid driving over some of the rather large saplings I mow down once in a while. I found a BH 307 for sale used locally, which had the ability to offset (it was a tow behind model) but realized it's a little too big for my tractor to handle.
To offset the box blade, I would think you could rather easily fabricate an adapter yourself, using two quick hitch setups (cheapo's that northern tool sells). Put one quick hitch on the 3 pt hitch, then you could weld the other quick hitch to some steel bars that connect the two, in a sideways fashion. I don't know if that makes sense, but it makes sense in my mind. :laughing:
   / Offset Attachment Adapter #9
I believe there are hydraulic-adjust-offset flail mowers ...copy their mechanics?
   / Offset Attachment Adapter #10
Seems to me you'd have to anchor the outside corner of the offset box blade somewhere on middle of the tractor. This would reduce the risk of bending whatever bar it was attached to and pivoting the tractor when the blade filled. Also agree with other posts that efficiency would be reduced.:2cents:
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
16ft Trailer (A50322)
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
