Offset PTO of Tajfun Winch Concern
   / Offset PTO of Tajfun Winch Concern #1
XTENON
Hello,
I'd like to know if implements which ask the pto shaft to run at a significant angle to the axis of the tractor do any harm to the tractor's pto?
Specifically, I'm wondering about the Tajfun model 30 skidding winch on a John Deere 950. I'm guessing the pto shaft would be 24"- 28" long and run at close to a 45 degree angle.
Unlike the Farmi and Fransgard winches whose pto hookups are centered, the Tajfun has the pto hookup side by side with, I believe, the drum. Need I be concerned with this?
Thanks.
   / Offset PTO of Tajfun Winch Concern #2
Xtenon,
I have a Tajfun winch and while the hook up is off set it is no where near 45 degrees. You have the pto shaft length right on, mine is 28" on a Kubota L2250. I have had mine for nearly a year and it has seen lots of use and no pto problems at all.
The Tajfun is a great winch and comes with more and larger cable than the Farmi as standard equipment. That being said the Farmi is also a high quality winch and you can't go with either one.
I do not know anything about the Fransgard.
Good Luck
Dave
Dave,
OK, I won't let the Tajfun's PTO deter me. It does seem to be alot of tool for the money. Thank you.
--David Yaz
   / Offset PTO of Tajfun Winch Concern #4
One thing about the Tajfun is that it has a friction brake, which apparently is safer than the mechanical brake on my Fransgard. Check out this review in "Sawmill Magazine" if you want to read more about the Tajfun.
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
ATV (A59231)
ATV (A59231)
Booster Cables (A59230)
Booster Cables...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
207272 (A52708)
207272 (A52708)
